[M] Continuous Fibre Arm Sketch
07/20/2022 at 00:13 • 0 commentsWhilst filling out the BOM spreadsheet to get a guage on pricing, I thought I'd just quickly sketch the reachable area of the SCARA. With a shoulder rotation of 180 degrees, the whole bed would be reachable, though there would need to be a fibre break somewhere in the middle if adding fibre to exceptionally long parts
[T] Continuous fibre attachment
07/19/2022 at 20:05 • 1 commentAs I've recently discovered and written about in this log, Desktop Metal seems to use a fibre tape to reinforce their parts. It's likely not as economical and wouldn't be as versatile as Markforge's offering, but I'd rather take "rough but within reach" over "fine line fairytale".
Considering that the SpaceApp, CostApp, PowerApp, TimeToDesignApp and ProgrammingProwessApp (where [X]App = limitation caused by [X]) is lower across the board with the SecSavr Suspence against the SecSavr Sublime, it makes sense to see what high priority features planned for the latter can be implemented in the former in some way. On the top of the list is fibre reinforced parts for the #TEOSS [gd0037] project. It's a shame that continuous fibre printing for hobbyists is still a project seldom anyone these days takes on, so I'd like to see what I can do. I can always get a PCB cheap overseas, but I can't say the same for CNC milled or continuous fibre parts.
The Initial Idea
I'm thinking of something similar to the printer below that has a gantry that can fully move out of the build area so that the next layer can be printed.Another option could be something resembling a SCARA, which may allow fitting the attachment inside the printer's footprint. Prints that use fibre are unlikely to need the full 32cm Z height (and neither Markforged or Ainsoprint have a print height over 21cm anyway). Full Y height would be most beneficial and X would probably be fine considering that it's fairly long already.
The SCARA idea is likely the better route overall because a) I could probably route all 3 axes so that the motors are stationaty and b) may be less intrusive if permantly installed in the printer.
[T] I'm going to try for 10 cartridges
07/19/2022 at 18:45 • 0 commentsI'd like to attempt 10 cartridges over 8 so that full 1-bit colour could theoretically be supported. It also allows me the option to leave a 2 or 3 high cartridge installed for print jobs that use a frequently used colour, such as white.
Now knowing this, I plan to use MGN9C for all linear motion. I'd imagine it'll make the BOM slightly less daunting to tackle.
[M] Roller now with LEDs
07/19/2022 at 11:11 • 0 comments -
[M] Roller Rail Holder
07/19/2022 at 02:52 • 0 commentsAnyway, I was hoping that my belt system idea would reduce the roller sides from the estimated 25mm in the concept, but that isn't the case since I needed to be able to mount to the outter carriage holes (the black bolts).
Part of the reason is the rail, for which I first mentally computed a solution that probably woudln't intersect the bed assembly. At least it looks more sleek and actually has a linear rail, unlike the concept model. I'm also trying a new way to do bolts in Fusion. Instead of having a file for each bolt length, have a file for the bolt head and, before importing it into the model, making a "Bolt" component. Then the head can be jointed to a part and a cylinder can be extruded to a specific length. Lastly, the body and the head component are asbuilt jointed.
Whilst computing the solution, I've established that the current order of dependencies is as follows:
- Desired X Axis length
- Roller length
- R Axis kinematics
- Y Axis kinematics
- Bed length
- Cartridge length
[M] Roller Belt
07/19/2022 at 00:19 • 0 commentsThe only issue right now is that I didn't expect the assembly to be 300mm instead of 260mm. Part of this is likely to do with the use of a 57mm roller instead of the original 50mm to get 179mm of rolling area instead of 159mm.
I wonder if I can use sensorless homing for this axis or if I'd have to also accommodate a limit switch.
[M] Aluminium plate simulation
07/18/2022 at 19:00 • 5 commentsI'm looking at my thickness options for the cast tooling plate and want to balance cost and weight reduction. For a 540x168mm bed, 5mm is £25, 6mm is £30, 8mm is £40 and 10mm is £50.
I went scanning on the internet for some calculator, but I have access to Fusion 360 so I used that instead to get a more accurate simulation. The plate is fixed up to 20mm away from the edges.
Simulating the bed with and without a part on it
The 6mm plate is 1469g and the 5mm is 1224g.
This is the 6mm bed with a 10N (approx 1kg) uniform load on the top. The max deflection is 34um which sounded pretty good so I went to 5mm.
I wanted to do a more localised force test, but first I wanted to see deflection of an empty bed.
Simulating pressing against the screen
I'm just going to assume a 2kg force is applied to the screen.
5mm isn't looking too good.
Conclusion
Considering the 250g difference in weight, £5 difference in price and better performance, I'll use the 6mm thickness. Before this simulation, I was thinking that I'd have to use 8, 10 or even 12mm. Considering I don't know all the factors just yet, I think 6mm is the safer decision. It's also closer to 1/4", which is likely a common cast tooling plate thickness.
[T] VLM as a wearable
07/18/2022 at 00:41 • 0 commentsHackady, why must you tempt me with a cool and exciting project? I feel like a mini, maybe even wearable printer based on VLM could make some real sense. One of the comments said something about an "Omni-tool".
It sounds like vaguely like a 3D printer and cyberdeck all-in-one. I can see that. A 3d printer, Compute Module 4 and #Tetent Tiny [gd0040] with a screen. To print anything actually useful (eg a screwdriver) , a length of 130cm or so would probably be required. Reading this hackaday article, it seems that dual material would be beneficial for dissolvable supports. Some mini activated carbon filter will also need to make an appearance.
I['m thinking of having the cartridges on the inside part of the arm and the build area on the outer side.
Other than the big questions about the Suspense I still have yet to answer, another 2 questions arise for this forearm wearable.
- How to make the cartridges gravity independent.
- Light source?
For the second question, my immediate choice would be this one:
[M] Carriages and 495mm X axis
07/16/2022 at 21:01 • 0 comments -
[E1][T] Photon M3 Screen
07/16/2022 at 13:18 • 0 commentsSo I'm browsing AliExpress and stumble upon the control board for the Photon M3.
Additionally, the Photon M3 screen was still available for the £54 price, and with more quanitities than 1 or 2.
Speed Calculations
But surely, FDM printers like the Sublime will still be faster when it comes to draft prints, so there's a need still.
Assuming 3 * 1.5s exposure for a 120um layer thickness and 3 seconds to change resin whilst cleaning the layer: 160 /(3600/7.5 * 0.12) = 2.7778 .78 * 60 = 46.8 minutes Time: 2h 47m.
*starts slicing with the CR10 0.8mm nozzle + 0.5mm layer height profile*
Ok so I just have to beat 2h 47m and the SecSavr Sublime isn't redundan--
Speeds?
Ok those might be a tad slow, maybe? Ok what if the change takes 6 seconds and not 3?
160 /(3600/10.5 * 0.12) = 3.8889
Still sub 4 hours!!
Ok. TestBox Profile Me. 0.8mm nozzle, 0.5mm layer height, 240mm/s everywhere, 16K print acceleration and 20K travel acceleration, 8% double-lined infill.
131/(3600/10.5 * 0.12) = 3.184 .184 * 60 = 11.04 Time: 3h 11m
It's... a tie?
[E1: 18th July] I didn't notice that Cura didn't save the new nozzle size when I changed it in settings.
Even with more realistic flow rates of 120mm/s and 9K acceleration isn't that much of a time penalty:
[E1 End]
Doesn't look like the 0.1mm layers would even need the 5 axis ironing step like for a 0.5mm FDM print.
Looking at the 8.9" screen again
8.9^2 / 6.6^2 = 1.8184 108 * 1.8 = 194.4 W source to match 108W COB
Now, writing this log, I realise that the screen sizes aren't square so the area difference is less than this. Anyway, I went off to look for that kind of power since the one at the store was only 120W.
The 7.6" 4K screen
At 4:53 am, I asked this:
The seller said that the 6.6" COB was the best option for what they had. I can confirm, since one of the options was this beast:
