BBTC
Big Beautiful Trump Card
This is a clone of Steve Ciarcia's Trump Card. The design uses a 512k x 16 bits RAM chip instead of the dynamic RAM. Also, all the glue logic is contained in a CPLD.
Test setup with the Z8001 Alien Probe installed on the BBTC.
JPEG Image - 1.11 MB - 05/22/2026 at 07:15
Preview
TrumpCard.pdf
The schematic of the bucket and glue logic in a pdf file.
Adobe Portable Document Format - 594.02 kB - 01/06/2026 at 09:23
Preview
TrumpCard-20260106.zip
The latest version of the CPLD files. Not the ... ok, you get it! For use in Quartus II. This is a untested version. It matches the circuit in the original TC, but something just doesn't work for now.
x-zip-compressed - 4.43 MB - 01/06/2026 at 09:20
Download
BOOT.bin
The combination of BOOTEVEN and BOOTODD into a single binary file
octet-stream - 600.00 bytes - 01/04/2026 at 10:49
Download
BOOT.asm
The disassembled code of BOOT.bin. I used this disassembler: https://github.com/OlliL/Z8000-Disassembler.
asm - 10.27 kB - 01/04/2026 at 10:49
Download
View all 20 files
  • 1 × EPM7128STC100-15 Logic ICs / Programmable Logic: PLDs
  • 1 × CY62157ELL-45ZSXI Memory ICs / Static RAM (SRAM)
  • 2 × 27C16 2k x 8 EPROM
  • 1 × Z8001P Microprocessors, Microcontrollers, DSPs / Microprocessors (MPUs)
  • 1 × Z8581 Clock and Timer ICs / Clock Generation and Distribution
View all 8 components
  • Debugging with the Z8001 Alien Probe
    Jacques Pelletier8 hours ago 0 comments
    The Alien probe was useful for checking the wiring and memories. Memories are working fine. Next step is to check the bit bucket with both the Z8001 and PC XT Alien Probes.
  • BBTC Project slowed down
    Jacques Pelletier01/24/2026 at 04:59 0 comments
    Last year, I had a lot of free time until late autumn. I returned to work in November, so my projects will slow down.
    The possible next steps:
    implement the Trump card with discrete logic to see if it works with the software
    making a simulator to run Z8000 code on Linux
    port this simulator to run in the Z8001 alien probe
    add a UART in the CPLD to help debugging or
    add an interceptor socket with which I can add peripherals to the current BBTC
    there is already a disassembler for the Z8000 running on Linux
  • Debugging the CPLD: 5
    Jacques Pelletier01/05/2026 at 04:46 0 comments
    I figured which chip goes where. I combined the 2 binary files and disassembled the result. I tried a disassembly of the swapped file but it was obviously not good so I scrapped it. I added the files in this project.
    Command to combine the 2 binary files:
    srec_cat -o BOOT.bin -binary BOOTODD -binary -unsplit 2 0 BOOTEVEN -binary -unsplit 2 1
     Location of boot chips:
    D8-15: BOOTEVEN
    U7 on BBTC, U21 on TC
    D0-7: BOOTODD
    U8 on BBTC, U22 on TC
    The listing in the original article seems to be an old version. The 2 files on the software disk are a derivative.
  • Debugging the CPLD: 4
    Jacques Pelletier01/04/2026 at 11:03 0 comments
    I tried swapping the 2 boot chips, same result. Removed both, same result.
    At this point, I need to know:
    Do the files BOOTEVEN and BOOTODD match the original Trump Card boot chips and which goes where (D0-7/D8-15)?
    I reproduced the circuit from the article except for the dynamic RAM. I know there was an error in the DRAM logic but that didn't affect my version. I don't know if there are difference between the schematic and the official Trump Card.
    If someone have a working Trump Card, I would like to see the result of the DIAG.COM program.
  • Debugging the CPLD: 3
    Jacques Pelletier01/03/2026 at 04:05 0 comments
    The initialization sequence in the article seems to be incomplete. I used the files BOOTEVEN and BOOTODD provided on the Trump Card's floppy disk.
    LDZSYS doesn't load either, but using diag.exe, I can test the bucket circuit further this time.
  • Debugging the CPLD: 2
    Jacques Pelletier01/02/2026 at 20:25 0 comments
    I used my PC XT alien probe to check every control lines, data and address bus.
    The CPLD was mysteriously keeping address A0 stuck at 0.
    There was no short with ground, so I added an inverter on A0 in the CPLD with the output going to an unused pin. There was no need to make any patch on the PCB (yet).
    With the pin A0 configured as an input, it was no longer hanging the bus and I could plug the BBTC on the PC XT motherboard.
    However, the BBTC still didn't work. LDZSYS was not able to connect to the Z8001, and the DIAG program remained stuck.
    The bucket simulation seems to work OK.
    The listing of the bootstrap initialization program doesn't match the files BOOTODD and BOOTEVEN.
    Jacques Pelletier12/30/2025 at 04:55 0 comments
    So far, the BBTC doesn't work. I removed all the chips on sockets. Only chip remaining on board is the RAM and CPLD.
    At this point, the BBTC's CPLD is programmed.
    When I plug the BBTC with the Nano 8088, the Nano 8088 doesn't boot. No video, no message, nothing at all. It boots normally if I remove the BBTC.
    I soldered an unprogrammed CPLD on an empty BBTC and I have the same result. When I put an empty BBTC, the Nano 8088 boots normally.
  • Nano 8088 working!
    Jacques Pelletier12/07/2025 at 05:40 0 comments
    Huge milestone reached!
    I also made a version 2 of the Nano 8088 board because the compact flash connector wasn't available anywhere. Fortunately, once assembled, the board worked! The compact flash doesn't seem to work yet. Once this works, I'll try to push my files on github to the same project.
    Meanwhile, I assembled 2 PCBs from Microcore Labs: the MCLZ8 and the MCL86+. That give alternatives to my alien probes for testing. At least I don't need to debug the 8088 anymore.
    The next test was to plug the BBTC on the passive motherboard along the Nano 8088 v2. Unfortunately, the card blocks the bus and nothing works. When I removed it, the Nano 8088 works normally.
    Next step will be to whip out my Alien Probes. Time to analyse this more deeply!
  • Debugging tools under way
    Jacques Pelletier11/18/2025 at 08:09 0 comments
    My assembled Trump card isn't tested yet, I need a PC to test it. I ordered a Nano 8088 kit with a motherboard but it doesn't work so I need to test both. I make some tools to be able to test the hardware at the lowest level. I call that Alien probes, the name says it all.
    I made one for the PC XT bus, one for the Z8001, one for the 8088 and a generic one to monitor bits and generate digital signals. These are based on the STM32F405 chip which is similar to the MCU on the black board I used on the Z80 ICE.
    I plan to make Alien Probes for other CPUs used in the retrocomputing community. This will help locate hardware faults.
  • Rechecking the bucket logic
    Jacques Pelletier10/13/2025 at 14:57 0 comments
    I just made a simulation model for the bucket logic.
    In the original Trump Card schematic, I noticed (what seems) a redundancy with the signal /BIOW at IC30 pin 13 and IC33 pin 12. That may explain the 470pF capacitor at the output of IC28 pin 9.
    While the original circuit modif may not be trivial, the CPLD version would be much easier to correct, and no need for capacitor.
View all 17 project logs
  • 1
    CPLD programming
    Get Quartus II 13.0 sp1 from Altera/Intel. The release 13.1 may work but I'm not sure. It's available for Linux and Windows. Search the web for Quartus II 13.1 download.
    Load the CPLD project, it should be already compiled and ready to upload to the CPLD.
    If you double-click on TrumpCard, it should open the file TrumpCard.bdf. It is a schematic of all the glue logic and the bit bucket interface.
    If the schematic is modified, compile it and program the chip in circuit with a USB Byte Blaster connected to the JTAG connector.
    To program the chip, in Quartus II, select Tools, Programmer,
    click on Hardware Setup, your Altera USB blaster should be visible. Clicking on Start should run the programming process.
    The Altera USB Blaster can be bought for cheap at AliExpress. The Quartus software will work fine with them.
View all instructions
Keith wrote 09/14/2025 at 21:07 point
A PC104 type connector would be very welcome. They are easier to get, and more compact, than ISA bus backplanes.
Jacques Pelletier wrote 09/23/2025 at 21:42 point
Good idea! I'm working on the PC104 version of the BBTC. I'll make the latches and buffer surface mount. The 6116 is also available in an SOIC format. I'll call it the SBTC, for Small BTC.
Keith wrote 09/14/2025 at 21:03 point
Trump card disks are also at archive.org:
https://archive.org/details/trump-card-disks
Jacques Pelletier wrote 09/10/2025 at 12:00 point
Yes, I have 4 spares. I'll sell them US$10 each + shipping costs.
My own PCB isn't tested yet, but schematic looks ok. I'll put instructions to program the CPLD.
If there is demand for it, maybe I can make a kit.
For your contact info, I don't know how to proceed. Thanks!
Keith wrote 09/10/2025 at 10:51 point
Bravo! I'd love to make one myself. Let me know if you have a spare PCB to sell! :-)
