Soft Propeller
DIPFORTy1 "Soft-Propeller" Zynq-7, Dual CortexA9+ FPGA
DIP40 Parallax Propeller I compatibles footprint
I have used Basic Stamp I, Scenix SX, all done by CHIP Gracey. I have never used Parallax Propeller, but now I will, implemented in FPGA logic, as Soft Proppeller.
Thank you Chip for releasing Propeller 1 verilog source code.
Of course this DIP can be used small FPGA board or Microcontrolller with custom periperals thanks to the ZYNQ on board.
System Design
Main Components/Features
  • Xilinx ZYNQ-7000
    • Dual ARM Cortex A9
    • 256K OCM RAM
  • 16MByte Flash, also useable as linear ROM
  • MicroSD Socket
  • Sil1143 Proximity and Ambient light sensor
  • RGB LED
  • DIP40 (Reversible pinout, not burning is inserted wrong!)
  • 3 times 5x2 pin-headers
    • JTAG + 2 I/O
    • 6 I/O
    • 4 I/O
  • Open Source Hardware
Licenses
  • CERN OHL
    • Hardware design
  • GPL
    • Propeller 1 Verilog
Note: propeller verilog was released under GPL, later there was offical statement on Parallax forums that commercial use is also acceptable without need to stick to GPL. This should be verified however. It seems some old forum threads have vanished. In any case once release under GPL can be used under GPL as this can not be revoked. And the use of Propeller code is not all required, it is just on possible use case.
  • 1 × XC7Z010 Logic ICs / Programmable Logic: FPGAs
  • 2 × EN5311 Power Management ICs / Switching Regulators and Controllers
  • 1 × RGB LED
  • 1 × si1143 Sensors / Proximity
  • 1 × S25FL127SABMFV10 Memory ICs / FLASH Memory
View all 7 components
  • Baseboard is being designed too
    Antti Lukats09/29/2015 at 19:38 0 comments
    While Soft-Propeller can be used on solderless breadboard, it is still good to have some base where it can be used and tested so that is now launched as separate project #HackBerry Pi
    It converts the Soft-Propeller into RPi form-factor and allows to use RPi hats
  • IT runs propeller code too :)
    Antti Lukats09/14/2015 at 14:02 0 comments
    While it was advertised as SOFT-PROPELLER, it was not until today it actually works as a Propeller.
    Testing on Parallax Development Board, flashed the SPIN code into EEPROM on Parallax board, and well Soft-Propeller configures itself from SPI flash as propeller and then loads prop code from EEPROM.
    Soft-Propeller has no on-board EEPROM, but this can be emulated in FPGA there are enough block rams free.
    Utilzation:
    FF: 15%
    LUT: 50%
    BRAM; 33%
  • MULTIBOOT Flash Image ready
    Antti Lukats09/13/2015 at 19:37 1 comment
    This may sound like small thing, but we have ready to ship Flash image that can either boot ARM Code from SD Card, or then execute multiboot process and configure every thing from second (application) Image in Flash.
    The second image could be Soft-Propeller or any thing else.
    Of course the code that would be loaded from SD Card can also configure the FPGA and load more software code from the SD card or the Code loaded from SD Card can update the Application image in Flash, so with next reset without the SD Card the new application would be loaded from SPI Flash.
  • Prop gets more memory
    Antti Lukats09/11/2015 at 09:51 1 comment
    DIPFORTy2 - a version with external memory and usb and hdmi seems to possible also.
    After doing 90 degrees turn the RAM routing looks doable, this is the most dense ZYNQ+DDR routing I have done so far:
    This may not be so impressive, but LPDDR2 with 0.65 mm pitch is directly under Zynq BGA with 0.8 mm pitch, and HDMI signals have be routed through the memory routing area, all this on PCB with no HDI technology, no buried no blind vias.
    It so often looks impossible until you just do it. LPDDR2 is directly below ZYNQ BGA, all signals routed in top bottom only, not internal signal layers used.
  • Propellers to Finland
    Antti Lukats09/10/2015 at 14:12 0 comments
    First Soft-Propellers left base, heading to Finland. Shipments to the rest of the world will go out next week.
    And we work on the documentation too, we do!
  • SD Card Bootloader working
    Antti Lukats09/09/2015 at 14:58 0 comments
    This may sound like a minor thing, but loading from SD card in the system with no external RAM and no bootrom bootable SD card is really tricky. Well its working now. Later the bootloader will possible use XiP, right it is like this:
    FSBL is loaded from Flash
    FSBL loads FPGA BITSTREAM from SPI Flash
    FPGA "adds" 128K RAM accessible to the CPU0
    FSBL loads SSBL from SPI Flash into RAM in FPGA
    SSBL Loads S-Records from file on the SD card into OCM RAM
    Your code from SD Card is running.
    At this point the RAM in FPGA is no longer used and we can re-program the FPGA from file on SD card, or update the SPI flash from SD card..
  • WS2812 IP Core Testing
    Antti Lukats09/07/2015 at 21:29 0 comments
    Vivado IP Catalog, click click.
    Vivado IP Integrator, click click.
    Xilinx SDK (Eclipse):
    void SetWS28xx(u8 RED, u8 GREEN, u8 BLUE) { putfsl(RED << 16 | GREEN << 8 | BLUE, 1); }
        while (1) {
        	SetWS28xx(r, g, b); //
        	r++;  	g++;  b++;
        	MB_Sleep(10);
    Solder iron, first convert WS2812 to SIPSIK(tm) compliant device, that easy just solder some header!
    Get 3 wires
    Connect the wires
    FAIL
    Get Oscilloscope, power it on
    Can not wait? Look at the wires again, SWAP ground and signal and
    you will see
    That WS2812 does work, and is controlled by software.
    This is first time I ever used WS2812.
    As soon as fixed the problem with the wiring, it just worked, namely:
    1. CPU0 Bootrom did load FSBL into OCM ram
    2. FSBL did load FPGA code that is the "HARDWARE" from an partition in the SPI Flash
    3. This BITSTREAM was DMA'd into ZYNQ PL - Programmable logic
    4. PLL in Processor part of ZYNQ was set to deliver clock to fabric side
    5. In the Programmable Fabric an 32 Bit Soft core MicroBlaze is booting from Block RAM that was loaded together with the bitstream during the FSBL boot proccesses
    6. Microblaze exectutes the main.c - code above
    7. The c code uses special processor instruction that directly writes the data to streaming hardware port
    8. This data is latched in WS2812 IP core
    9. The IP core generates the timing
    10. WS2812 is controlled by the software :)
    You think this can not be true?
    That this all just works first time tested?
    Well then you would not believe I can do #HAD-9000 in 2016 either?
    Without your help, I can not. With your help WE can.
    Would you like to work on HAD-9000 ? You can.
    You can start now with Soft-Propeller, its gives the boost you need to be ready for HAD-9000 in 2016.
  • SDSoC first tests
    Antti Lukats09/07/2015 at 20:20 0 comments
    This is exciting, I think in the next year it will mature, Xilinx SDSoC
    http://www.xilinx.com/products/design-tools/software-zone/sdsoc.html
    To cut the bla, its really simple: You select platform, say Soft-Propeller, in Eclipse, write some C code, and you get ready to run image that works on the ARM Cores and is partially compiled directly into FPGA hardware.
    This works now. It does! SDSoC 2015.2 is first public release so expect some issues, but the basic flow really works.
  • 59 EUR - Lowest cost ZYNQ mod ever!
    Antti Lukats09/07/2015 at 09:57 0 comments
    DIPFORTy1 "Soft-Propeller" is
    1. Lowest Cost ZYNQ based Module ever made
    2. First ZYNQ module that can use existing bases and project boards (Parallax Propeller chip compatibility)
    3. First ZYNQ based product ever in Hackaday Prize semifinals
    4. First Xilinx 7 Series based product ever in Hackaday Prize semifinals
    Downloads
    Order link
    Note: TE0722 - warehouse software assigned number :)
    Note 2: the Hardware Design files are on github...
  • Prelimary pricing, docu-wiki!
    Antti Lukats09/03/2015 at 10:50 3 comments
    Price: 69 EUR
    This makes it lowest cost Module with Xilinx ZYNQ technology avaiilable.
    Order now
    DIPFORTy1
    new name, DIP40 = DIPFORTy
    Number 1 is sub-product type: DIPFORTy1 is first one in the family with code name "Soft-Propeller"
View all 22 project logs
Rich text editor
toshas wrote 10/20/2016 at 07:06 point
Hi!
Now I can see both revisions in stock on Trenz website.
Could you explain what is the difference between REV1 and REV2. I mean what kind of SCH/PCB bugs you solved in REV2.
Will REV2 sources (AD project) be uploaded on github ?
Thanks a lot! It's amazing project!
David Betz wrote 03/11/2016 at 03:57 point
Any update on the availablity of this product? I still haven't received the one I ordered.
David Betz wrote 12/11/2015 at 03:57 point
Has anyone ever received one of these modules? I ordered ages ago and have heard nothing.
Antti Lukats wrote 12/11/2015 at 09:28 point
we just have REV 2 PCB manufactured, they are on hold until i release the factory image for flashing..
Jac Goudsmit wrote 10/09/2015 at 22:51 point
Hey Antti, what source code are you using to program the FPGA? I don't see it in the https://github.com/AnttiLukats/Soft-Propeller repo. If you have it elsewhere in Github (or on another public Github server of course) I would like to branch/merge/integrate your Verilog code into my P1V repo at https://github.com/JacGoudsmit/P1V. Thanks!
Leon Heller wrote 09/30/2015 at 10:29 point
I've just ordered one from Trenz.
Antti assembles them to order (2-3 days). Cost was 70.21 Euros:
http://shop.trenz-electronic.de/en/search?sSearch=te0722
Email them first, and don't take any notice of the zero stock.
Antti Lukats wrote 09/30/2015 at 10:31 point
well we have small stock, but the TESTING is currently on my desk still, yes..
Djs wrote 08/21/2015 at 09:14 point
how can we buy one board?
Antti Lukats wrote 08/21/2015 at 09:23 point
http://www.trenz-electronic.de/meta-navigation/imprint-disclaimer.html
just send email, they are not in online shop, but we have them ready to ship :) !
Glenn wrote 08/23/2015 at 18:06 point
HI Antti, what will be the cost in USD?
hatakilkn wrote 07/27/2015 at 06:48 point
Hello, Actually i am working on a project using Zynq7000 Socs, but i need more IOs in my design. How many IOs is it possible to add to your project?
Thanks,
Antti Lukats wrote 07/27/2015 at 07:24 point
in dip socket are 34 io, if you count all connectors then 42 io + 3 more input only pins are available
hatakilkn wrote 07/27/2015 at 07:36 point
Excuse me, you mean that I can use 45 more IOS and this board countains already 34 IO ?
Thanks,
Antti Lukats wrote 07/27/2015 at 10:02 point
no, sorry: in the DIP40 header: 34, in the other headers: 4 + 6 + 2 + 3 input only, so abs total max use: 42 + 3
hatakilkn wrote 07/27/2015 at 10:54 point
In my project i will be using about 80 IOS, is it possible to redesign the PCB and extract more IOS for example or what do you advice me to do.
Thanks,
hatakilkn wrote 07/27/2015 at 10:59 point
and excuse me for this question what is the designation of the NAND Flash, because the documentation doesn't indicate.
Thanks,
Antti Lukats wrote 07/27/2015 at 11:01 point
16mmyte quad spi serial nor flash, can be accesses as XiP linear memory also, no nand
hatakilkn wrote 07/27/2015 at 11:17 point
Thnks for the informations, but what is its reference in the Design that you putt in GitHub ?
Thanks,
Antti Lukats wrote 07/27/2015 at 12:05 point
Nothing yet, but for sure there would be propeller demo, and some logic analyzer, and maybe something else to get started.
I am on vacation actually, so my time is clustered and limited atm.. hence the random replies
Antti Lukats wrote 07/27/2015 at 14:15 point
Clg225 has total 54 fpga io and some on the processing system so with package 80 io is not directly possible. But if your system includes slow and fast peripherals you may add io by using say simple serial registers fpga can scan them very fast
Jorge Lacoste wrote 07/22/2015 at 16:06 point
Are you going to be posting the design files? I would be curious to see the schematic and layout documents. Which tool did you use to do the board layout?
Thanks,
Antti Lukats wrote 07/22/2015 at 18:53 point
Altium, and yes will get published the CAD source files.
CarlosL wrote 07/23/2015 at 13:59 point
Oh so great.
By the way, if you release the CAD for OZoM before this you round my day.
https://www.indiegogo.com/projects/ozom-open-source-zynq-on-module
Antti Lukats wrote 07/23/2015 at 20:21 point
ozom-a CAD files are actually released, they are on public access SVN server, with not so widely known url.. i try to change this, probably by duplicating the sources to github or somewhere else
CarlosL wrote 07/25/2015 at 11:14 point
Oh! so far so good :D
Can you post the URL on indegogo page? We're waiting like KIDs on christmas.
Thanks for your job,
C.
Antti Lukats wrote 07/25/2015 at 11:58 point
uups, the SVN path was not visible, I was mistaken, so:
https://github.com/AnttiLukats/OZOM-Model-A
this are the original sources for the first batch manufactured, I push the info to other places too
Victor Suarez Rovere wrote 07/19/2015 at 00:01 point
can you run more than 8 cogs? How many LE are available now?
Antti Lukats wrote 07/19/2015 at 11:51 point
see project log, I compiled prop v1 code for 7010 its about 50% of LUTs. Xilinx does not count LE as Altera. Bit more than 50% of LUTs are used from other resources less than half.
Antti Lukats wrote 07/17/2015 at 18:33 point
BGA is simple both for manual as for automatic assembly. As long as you do not go below 0.8mm pitch, you can use pretty much any PCB fab. The fab we use for small batches does have production panel size of 360x460mm, and no discount on repeated order, and prices go up if you order more boards. You pretty much pay for the full 360x460mm always, or it does never make sense to order less than 1 full panel (this could be your multiproject pcb with 50 projects..). The price of one panel is from 300 to 1000 eur. I do not recall what the DIP40 boards did cost, it is OK for first runs, for larger volume we need to use other fab. For small runs:
www.brandner.ee
you can check out their capabilities :)
TommiRouvali wrote 07/17/2015 at 18:19 point
Hi, cool project! Can you comment on what PCB factory you used and how much that one panel cost? I have done some Spartan 3 and Spartan 6 projects with TQFP-package and 2 layer PCB. But all good stuff seems to be packed on BGA:s now days, so I am very curious how to get there.
Antti Lukats wrote 07/16/2015 at 10:53 point
We produced 1 pane = 4 PCBs, we had 5 pieces of ZYNQ for $$$ money, we have ordered from "quote pricing" - but this takes some time to arrive. But we do our best not to delay. We have some PCBs from first batch, stencil is there. So we do more testing, and then its up to Avnet when they deliver the Zynq.
DaveG wrote 07/16/2015 at 09:36 point
This is awesome! Now shut up and take my money!
Antti Lukats wrote 07/16/2015 at 07:03 point
it is 6 Layer PCB, yes I will post more pics, the board just was produced yesterday so I had no time to make real photos, just with my handy some quick shots..
Djs wrote 07/16/2015 at 03:53 point
This is a great product that I wish to have couple of them, can you please post the back side pictures?
S J wrote 07/15/2015 at 20:58 point
This is amazing. I'm so excited to see a ZYNQ board :)
Just out of curiosity how many layers does the PCB have?
