System Design
Main Components/Features
- Xilinx ZYNQ-7000
- Dual ARM Cortex A9
- 256K OCM RAM
- 16MByte Flash, also useable as linear ROM
- MicroSD Socket
- Sil1143 Proximity and Ambient light sensor
- RGB LED
- DIP40 (Reversible pinout, not burning is inserted wrong!)
- 3 times 5x2 pin-headers
- JTAG + 2 I/O
- 6 I/O
- 4 I/O
- Open Source Hardware
Licenses
- CERN OHL
- Hardware design
- GPL
- Propeller 1 Verilog
Note: propeller verilog was released under GPL, later there was offical statement on Parallax forums that commercial use is also acceptable without need to stick to GPL. This should be verified however. It seems some old forum threads have vanished. In any case once release under GPL can be used under GPL as this can not be revoked. And the use of Propeller code is not all required, it is just on possible use case.
Antti Lukats
Robert Gawron
Dan Julio
Hi!
Now I can see both revisions in stock on Trenz website.
Could you explain what is the difference between REV1 and REV2. I mean what kind of SCH/PCB bugs you solved in REV2.
Will REV2 sources (AD project) be uploaded on github ?
Thanks a lot! It's amazing project!
